Saltar al contenido principal
HP Envy x360 15m-bp111dx Cooling Fan Replacement
Eli Porter
Eli Porter y 5 otros contribuidores
Última actualización: May 23, 2024
25 - 40 minutos
Moderado
Introducción
Ir al paso 1
This guide will be utilized to locate, remove, and replace the cooling fan of your HP Envy x360 15m-bp111dx. If your laptop has a clicking fan, or you suspect that there is a problem with the CPU fan/heat sink, use this guide to replace the CPU fan and heat sink. The fan and heat sink work together to draw heat away from the CPU, keeping it cool and allowing your device to run as efficiently as possible. If your fan is broken, it can cause a clicking sound or could lead to your device overheating.
Before using this guide, ensure that the venting holes on the back of the laptop are clear of dust and debris. Typically, you can remove dust and buildup with a small dust blower. Restart the machine to ensure the fan is still clicking.
The final step requires you to re-apply thermal paste onto the CPU. If you skip this step, you will almost certainly damage your machine.
Be sure that your laptop is powered off, disconnected from the power adapter, and that the components have cooled before beginning this replacement guide.
Qué necesitas
Herramientas
Ver más…
  1. HP Envy x360 15m-bp111dx Cooling Fan Replacement, Back Panel: paso 1, imagen 1 de 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 2, imagen 3 de 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Cooling Fan Replacement, Cooling Fan: paso 3, imagen 1 de 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement, Cooling Fan: paso 3, imagen 2 de 2
    • Remove the three 4 mm fan screws using a Phillips screwdriver.
  4. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 4, imagen 1 de 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Loosen the screws on the heatsink using the Phillips screwdriver.
    • Do not force the screws to come out of the heatsink; they are meant to stay in place.
  5. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Remove the tape from the heat sink by pulling upwards.
  6. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, remove the sliding connector directly beside the fan.
  7. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 7, imagen 1 de 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 7, imagen 2 de 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 7, imagen 3 de 3
    • Lift the fan assembly from the computer to remove it.
  8. HP Envy x360 15m-bp111dx Cooling Fan Replacement: paso 8, imagen 1 de 1
    • Replace the thermal paste on the processor using the following guide.
Conclusión
Una persona más ha completado esta guía.
Eli Porter
Miembro Desde 02/22/22
145 Reputación
1 Guía escrita
Equipo
Clemson, Team 2-2, Hunter Spring 2022 Miembro de Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 393
