Saltar al contenido principal
HP Envy dv6-7363cl Keyboard Replacement
austin urban
austin urban y 2 otros contribuidores
Última actualización: June 12, 2018
5 minuto
Moderado
Introducción
Ir al paso 1
Reader will be able to successfully replace their keyboard of the device. A basic understanding of simple tools such as a screwdriver is needed. Any form of electricity must be removed from device, including the charging cable and battery.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  1. HP Envy dv6-7363cl Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Start by opening the laptop
  2. HP Envy dv6-7363cl Keyboard Replacement: paso 2, imagen 1 de 3 HP Envy dv6-7363cl Keyboard Replacement: paso 2, imagen 2 de 3 HP Envy dv6-7363cl Keyboard Replacement: paso 2, imagen 3 de 3
    • Pry off the keyboard retainer slowly working your way around the board to prevent damage
  3. HP Envy dv6-7363cl Keyboard Replacement: paso 3, imagen 1 de 2 HP Envy dv6-7363cl Keyboard Replacement: paso 3, imagen 2 de 2
    • Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board
  4. HP Envy dv6-7363cl Keyboard Replacement: paso 4, imagen 1 de 2 HP Envy dv6-7363cl Keyboard Replacement: paso 4, imagen 2 de 2
    • Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard.
Conclusión
austin urban
Miembro Desde 03/19/18
159 Reputación
1 Guía escrita
Equipo
Un comentario
Salom shu kampyuterni ustgi qopqogʻi kerak topishni iloji bormi
Shamsullo Quzratov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 537
