Saltar al contenido principal
HP Envy X2-15-C001Dx Battery Replacement
Cole Escobar
Cole Escobar y 5 otros contribuidores
Última actualización: January 10, 2025
15 - 25 minutos
Moderado
Introducción
Ir al paso 1
This guide provides step-by-step instructions for removing and replacing the battery in the HP Envy X2-15-C001Dx laptop.
A healthy battery is crucial for your laptop's portability, and a faulty one can cause power issues and potential safety risks. Replacing the battery will enhance the overall health of the device.
If you're dealing with rapid battery drain or other power-related problems, this guide will help you troubleshoot and fix the issue. Before starting, make sure the device is powered off and unplugged to ensure safety throughout the process.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Ver más…
  1. HP Envy X2-15-C001Dx Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Battery Replacement: paso 2, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 2, imagen 2 de 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Battery Replacement: paso 3, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 3, imagen 2 de 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Battery Replacement: paso 4, imagen 1 de 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Battery Replacement: paso 5, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 5, imagen 2 de 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Battery Replacement: paso 6, imagen 1 de 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Battery Replacement: paso 7, imagen 1 de 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Battery Replacement: paso 8, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 8, imagen 2 de 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Battery Replacement: paso 9, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 9, imagen 2 de 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Battery Replacement: paso 10, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 10, imagen 2 de 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Battery Replacement, Battery: paso 11, imagen 1 de 3 HP Envy X2-15-C001Dx Battery Replacement, Battery: paso 11, imagen 2 de 3 HP Envy X2-15-C001Dx Battery Replacement, Battery: paso 11, imagen 3 de 3
    • Gently unplug the battery connector from the motherboard by carefully gripping the connector and pulling it straight out. Avoid tugging on the wires to prevent damage. Ensure the connector is fully detached before proceeding with any further steps.
  12. HP Envy X2-15-C001Dx Battery Replacement: paso 12, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 12, imagen 2 de 2
    • Using a functioning screwdriver i.e Phillips #1 screwdriver, carefully remove the eight screws securing the battery to the device. Unscrew each one slowly and set them aside in a safe spot, like a small container, to prevent loss. Ensure all screws are completely removed and that the battery is fully detached before proceeding to lift it out.
  13. HP Envy X2-15-C001Dx Battery Replacement: paso 13, imagen 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: paso 13, imagen 2 de 2
    • Carefully remove the battery by gently lifting it out of the device. Ensure there are no remaining screws or cables attached before lifting. Hold the battery securely with both hands to avoid dropping or damaging it, and place it on a clean, static-free surface for safety.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 personas más completaron esta guía.
Cole Escobar
Miembro Desde 10/25/21
202 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
Miembros de 3
6 Guías creadas
Un comentario
There is not need to remove the back hinge. Step 4 can be omitted.
In Step 8 I found two additonal screws to the left and right, close to the corner. These are not shown here in the pictures.
When opening the case as in step 9, then the top corners are the hardest to open. The bottom is easiest.
Genrally I recommend using an antistatic mat and a wristband, when opening electronics.
alter einstein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 477
