Saltar al contenido principal
Fixed Gear Bike Chainring Replacement
aljndro__
aljndro__ y otro contribuidor
Última actualización: December 28, 2023
15 - 25 minutos
Fácil
Introducción
Ir al paso 1
Do you also own a fixed gear or a track bike? Fixed-gear bikes generally have fewer components and parts than any other bikes. A chain ring plays a vital role in the drive train and is attached to the crankset. As the bike ages, and the more miles you put on your fixie, the higher the chances of the chainring getting worn down. Replacing a worn-out chainring benefits the quality of your bike rides and drivetrain longevity.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Fixed Gear Bike Chainring Replacement, Chainring: paso 1, imagen 1 de 2 Fixed Gear Bike Chainring Replacement, Chainring: paso 1, imagen 2 de 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: paso 2, imagen 1 de 2 Fixed Gear Bike Chainring Replacement: paso 2, imagen 2 de 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: paso 3, imagen 1 de 2 Fixed Gear Bike Chainring Replacement: paso 3, imagen 2 de 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: paso 4, imagen 1 de 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: paso 5, imagen 1 de 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Linea de Meta
aljndro__
Miembro Desde 08/22/23
121 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Miembro de CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 261
