Saltar al contenido principal
Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement
Carsten Frauenheim
Carsten Frauenheim
Última actualización: June 29, 2021
45 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
This guide shows how to remove and replace the clutch spring in an Echo SRM-2620U Brushcutter.
  1. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: paso 1, imagen 1 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: paso 1, imagen 2 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: paso 1, imagen 3 de 3
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: paso 2, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: paso 2, imagen 2 de 2
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 3, imagen 1 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 3, imagen 2 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 3, imagen 3 de 3
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: paso 4, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: paso 4, imagen 2 de 2
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 5, imagen 1 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 5, imagen 2 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 5, imagen 3 de 3
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: paso 6, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: paso 6, imagen 2 de 2
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 7, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 7, imagen 2 de 2
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the fan cover: paso 8, imagen 1 de 1
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 9, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 9, imagen 2 de 2
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: paso 10, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: paso 10, imagen 2 de 2
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Separate the shaft from the engine assembly: paso 11, imagen 1 de 1
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 12, imagen 1 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 12, imagen 2 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 12, imagen 3 de 3
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch cover: paso 13, imagen 1 de 1
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 14, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 14, imagen 2 de 2
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch assembly: paso 15, imagen 1 de 1
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 16, imagen 1 de 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 16, imagen 2 de 2
    • Remove the clutch assembly.
  17. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: paso 17, imagen 1 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: paso 17, imagen 2 de 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: paso 17, imagen 3 de 3
    • Firmly grip one clutch shoe in each hand and twist them apart to release the spring tension.
    • During reassembly, loop the clutch spring in place on the clutch shoes and twist them together to reapply spring tension.
    • Disconnect one side of the spring loop from one of the clutch shoes.
  18. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: paso 18, imagen 1 de 1
    • Remove the spring from the remaining clutch shoe.
Conclusión
Carsten Frauenheim
Miembro Desde 03/10/20
136,339 Reputación
371 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,564 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 195
