Disassembling Canon PowerShot SD850 IS Case Removal
Introducción
Ir al paso 1How to remove the outer casing of your Canon PowerShot SD850 IS.
Qué necesitas
Herramientas
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
3 personas más completaron esta guía.
Un comentario
Had to exchange a battery/SD card cover on an Ixus970IS. This guide very helpful showing the way due to similar layout of the Ixus and the PS850IS! Thanx a lot! :-)
KBK Copenhagen DK
