Saltar al contenido principal
Dell XPS 15 9500 Base Panel Replacement
Connor
Connor y 2 otros contribuidores
Última actualización: June 7, 2024
1 - 3 minutos
Fácil
Introducción
Ir al paso 1
Welcome to the Dell XPS 15 9500 Base Panel Replacement guide. Here, we'll walk you through safely removing and replacing the base panel on your laptop. This repair might be necessary if your laptop has suffered damage from drops or impacts, or if you need access to internal components like the battery or storage drive. Additionally, cleaning the base panel can improve airflow, helping to resolve overheating or performance issues.
Qué necesitas
Herramientas
  1. Dell XPS 15 9500 Base Panel Replacement, Base Panel: paso 1, imagen 1 de 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Base Panel Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9500 Base Panel Replacement: paso 2, imagen 2 de 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
Conclusión
Connor
Miembro Desde 03/29/22
12,218 Reputación
64 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,465 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 2,795
