Saltar al contenido principal
Dell XPS 13 Track Pad Replacement
Arvind Krish
Arvind Krish y 4 otros contribuidores
Última actualización: January 9, 2025
5 minuto
Fácil
Pasos faltantes
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Introducción
Ir al paso 1
Use this guide to replace the track pad in the Dell XPS 13.
Qué necesitas
Herramientas
Ver más…
  1. Dell XPS 13 Track Pad Replacement, Back Cover: paso 1, imagen 1 de 2 Dell XPS 13 Track Pad Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Track Pad Replacement: paso 2, imagen 1 de 2 Dell XPS 13 Track Pad Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Track Pad Replacement: paso 3, imagen 1 de 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Track Pad Replacement: paso 4, imagen 1 de 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Track Pad Replacement: paso 5, imagen 1 de 1
    • Remove the bottom cover.
  6. Dell XPS 13 Track Pad Replacement, Battery Disconnection: paso 6, imagen 1 de 2 Dell XPS 13 Track Pad Replacement, Battery Disconnection: paso 6, imagen 2 de 2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Track Pad Replacement, Battery: paso 7, imagen 1 de 2 Dell XPS 13 Track Pad Replacement, Battery: paso 7, imagen 2 de 2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Track Pad Replacement: paso 8, imagen 1 de 2 Dell XPS 13 Track Pad Replacement: paso 8, imagen 2 de 2
    • Do not pull up.
  9. Dell XPS 13 Track Pad Replacement: paso 9, imagen 1 de 1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Track Pad Replacement: paso 10, imagen 1 de 1
    • Remove the battery.
  11. Dell XPS 13 Track Pad Replacement, Track Pad: paso 11, imagen 1 de 2 Dell XPS 13 Track Pad Replacement, Track Pad: paso 11, imagen 2 de 2
    • Remove the four 3 mm Phillips #1 screws from the trackpad.
  12. Dell XPS 13 Track Pad Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to gently lift the upper-right corner of the track pad.
    • Remove the track pad by slowly pulling it up and away from you.
Conclusión
6 personas más completaron esta guía.
Arvind Krish
Miembro Desde 04/26/17
215 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S21-G6, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
Miembros de 5
30 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 150
Todo El Tiempo: 14,843
