Saltar al contenido principal
Dell Vostro 5510 Display Assembly Replacement
Shawn Pan
Shawn Pan y otro contribuidor
Última actualización: June 11, 2024
3 - 5 minutos
Fácil
Introducción
Ir al paso 1
This guide will walk through how to replace the display assembly of the Dell Vostro 5510 laptop. The purpose/function of a display is to be able to view information given on a laptop. Symptoms of a display not working is if it displays No Signal or if it doesn't display anything other than a black screen. If the laptop is powered on but the screen displays No Signal, see this link for troubleshooting the problem/issue: Monitor No Signal. Furthermore, if the laptop doesn't display anything other than a black screen even after powering it on, restarting the video drivers, and resetting the RAM, the parts/components of the laptop screen must be broken down and replaced by following the steps below.
Qué necesitas
Herramientas
  1. Dell Vostro 5510 Display Assembly Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Display Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Display Assembly Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 Display Assembly Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 Display Assembly Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Display Assembly Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 Display Assembly Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Display Assembly Replacement, Display Assembly: paso 5, imagen 1 de 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: paso 5, imagen 2 de 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: paso 5, imagen 3 de 3
    • Remove the six 4 mm hinge screws using the Phillips #0 screwdriver.
  6. Dell Vostro 5510 Display Assembly Replacement: paso 6, imagen 1 de 2 Dell Vostro 5510 Display Assembly Replacement: paso 6, imagen 2 de 2
    • Flip up the hinge panel for the left side of the laptop.
    • Flip up the hinge panel for the right side of the laptop.
  7. Dell Vostro 5510 Display Assembly Replacement: paso 7, imagen 1 de 2 Dell Vostro 5510 Display Assembly Replacement: paso 7, imagen 2 de 2
    • Disconnect the display cable with your hands.
  8. Dell Vostro 5510 Display Assembly Replacement: paso 8, imagen 1 de 1
    • Lift up the laptop with your hands to detach it from the display assembly.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 173
