Saltar al contenido principal
Dell Precision M3800 RAM (Memory) Replacement
Brianna Hitchcock
Brianna Hitchcock y 2 otros contribuidores
Última actualización: December 6, 2019
5 - 10 minutos
Fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
If the Dell Precision M3800 is showing the “Blue Screen of Death” or any other error mentioning RAM or memory issues, use this guide to replace the RAM.
The RAM in a computer functions as the memory, and faulty RAM can cause errors in the computer that stop it from functioning.
Before beginning, be sure to power down the laptop, and unplug from the external power source(s).
Qué necesitas
Herramientas
Ver más…
  1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: paso 1, imagen 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 RAM (Memory) Replacement: paso 2, imagen 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 RAM (Memory) Replacement, Battery: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): paso 4, imagen 1 de 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): paso 4, imagen 2 de 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): paso 4, imagen 3 de 3
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 473
