Saltar al contenido principal
Dell Latitude D531 Memory chip (RAM) Replacement
Hezekiah Brown
Hezekiah Brown y otro contribuidor
Última actualización: June 17, 2021
4 - 7 minutos
Moderado
Necesita mejores imágenes
Necesita más imágenes
Guía aportada por comunidad
Mejor introducción
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery from the computer.
    • Remove hinge cover and keyboard from the computer.
    • The computer has two memory slots, DIMM A and DIMM B. DIMM A is located on top of the computer under the keyboard, and DIMM B is located on the bottom of the computer under the memory module cover.
    • DIMM A holds the basic memory module as configured from the factory. If you did not order additional memory, DIMM B is empty. Generally, if you add memory, you use DIMM B. If you are upgrading memory, you may need to install memory in DIMM A and DIMM B, depending on the extent of the upgrade.
    • Ground yourself by touching one of the metal connectors on the back of the computer.
    • If you leave the area, ground yourself again when you return to the computer.
  1. Dell Latitude D531 Memory chip (RAM) Replacement, DIMM A Connector RAM - Step 1: paso 5, imagen 1 de 1
    • To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    • Insert memory modules at a 45-degree angle to avoid damaging the connector. If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • Ground yourself and install the new memory module by aligning the notch in the module edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • Insert or replace the keyboard, hinge cover, and battery on the computer respectively.
    • After turning on your computer, it should detect the amount of RAM installed, if RAM is installed correctly.
    • If you're willing to replace or install the memory module/chip in the DIMM B connector, only insert or replace the keyboard and hinge cover.
  2. Dell Latitude D531 Memory chip (RAM) Replacement, DIMM B Connector RAM - Step 1: paso 8, imagen 1 de 1
    • If you haven't done so, shut down your computer. Disconnect all power sources before opening the computer cover or panels. Remove the battery afterward.
    • Turn the computer upside-down, loosen the captive screw on the memory module cover (see image), and remove the cover.
  3. Dell Latitude D531 Memory chip (RAM) Replacement, DIMM B Connector RAM - Step 2: paso 9, imagen 1 de 1
    • If you are replacing a memory module, remove the existing module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • For optimal performance, identical memory modules should be used in each connector.
    • Replace the memory module cover.
    • If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • Insert the battery into the battery bay, or connect the AC adapter (charger) to your computer and an electrical outlet.
    • Turn on the computer.
Conclusión
Hezekiah Brown
Miembro Desde 02/11/21
6,169 Reputación
49 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 237
