Saltar al contenido principal
Dell Chromebook 5190 WLAN Card Replacement
Brian
Brian y 2 otros contribuidores
Última actualización: June 20, 2022
35 - 40 minutos
Moderado
Introducción
Ir al paso 1
This guide will aid you in replacing your Dell Chromebook 5190 WLAN card.
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
If your laptop is having trouble or failing to connect Wi-fi, the WLAN card may be the issue. Make sure to check the troubleshooting page first. If the same problem persists, then you will need to replace the WLAN card.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Chromebook 5190 WLAN Card Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 WLAN Card Replacement: paso 2, imagen 1 de 3 Dell Chromebook 5190 WLAN Card Replacement: paso 2, imagen 2 de 3 Dell Chromebook 5190 WLAN Card Replacement: paso 2, imagen 3 de 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 WLAN Card Replacement: paso 3, imagen 1 de 2 Dell Chromebook 5190 WLAN Card Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 WLAN Card Replacement: paso 4, imagen 1 de 2 Dell Chromebook 5190 WLAN Card Replacement: paso 4, imagen 2 de 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 WLAN Card Replacement: paso 5, imagen 1 de 2 Dell Chromebook 5190 WLAN Card Replacement: paso 5, imagen 2 de 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 WLAN Card Replacement: paso 6, imagen 1 de 3 Dell Chromebook 5190 WLAN Card Replacement: paso 6, imagen 2 de 3 Dell Chromebook 5190 WLAN Card Replacement: paso 6, imagen 3 de 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: paso 7, imagen 1 de 2 Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: paso 7, imagen 2 de 2
    • Unscrew and remove the M2x3 screw.
    • Remove the metal bracket.
  8. Dell Chromebook 5190 WLAN Card Replacement: paso 8, imagen 1 de 1
    • Remove WLAN antennas.
  9. Dell Chromebook 5190 WLAN Card Replacement: paso 9, imagen 1 de 1
    • Slide the WLAN card away from the motherboard.
Conclusión
Brian
Miembro Desde 02/10/22
97 Reputación
1 Guía escrita
Equipo
Gateway, Team 1-3, Pee Spring 2022 Miembro de Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 146
