Saltar al contenido principal
Dell Chromebook 5190 Speaker Replacement
Denise Cano
Denise Cano y 3 otros contribuidores
Última actualización: June 20, 2022
Sin estimación
Moderado
Introducción
Ir al paso 1
This guide will aid you in replacing your Dell Chromebook 5190 speaker.
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
In order to help you hear your audio clearly, you need functioning speakers. Audio may be distorted for a number of reasons, be sure to check this device's troubleshooting page to check for possible solutions. If you are still experiencing these issues after troubleshooting, you may need to replace your speaker.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Chromebook 5190 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Speaker Replacement: paso 2, imagen 1 de 3 Dell Chromebook 5190 Speaker Replacement: paso 2, imagen 2 de 3 Dell Chromebook 5190 Speaker Replacement: paso 2, imagen 3 de 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Speaker Replacement: paso 3, imagen 1 de 2 Dell Chromebook 5190 Speaker Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Speaker Replacement: paso 4, imagen 1 de 2 Dell Chromebook 5190 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Speaker Replacement: paso 5, imagen 1 de 2 Dell Chromebook 5190 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Speaker Replacement: paso 6, imagen 1 de 3 Dell Chromebook 5190 Speaker Replacement: paso 6, imagen 2 de 3 Dell Chromebook 5190 Speaker Replacement: paso 6, imagen 3 de 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 Speaker Replacement, Speaker: paso 7, imagen 1 de 1
    • Remove the speaker cable by pulling it from the motherboard.
  8. Dell Chromebook 5190 Speaker Replacement: paso 8, imagen 1 de 2 Dell Chromebook 5190 Speaker Replacement: paso 8, imagen 2 de 2
    • Peel the clear adhesive tape that secures the speaker cables.
    • Peel the 2 black adhesive tapes near the bottom of the system.
  9. Dell Chromebook 5190 Speaker Replacement: paso 9, imagen 1 de 3 Dell Chromebook 5190 Speaker Replacement: paso 9, imagen 2 de 3 Dell Chromebook 5190 Speaker Replacement: paso 9, imagen 3 de 3
    • Unroute the speaker cable from the speaker connectors.
    • Lift the speaker away from the system.
Conclusión
Denise Cano
Miembro Desde 02/10/22
617 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-3, Pee Spring 2022 Miembro de Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 192
