Saltar al contenido principal
Dell Chromebook 5190 Motherboard Replacement
Denise Cano
Denise Cano y 2 otros contribuidores
Última actualización: June 20, 2022
20 - 30 minutos
Moderado
Introducción
Ir al paso 1
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
The system board, also known as the motherboard, is the backbone of the computer; it allows all major components of your computer hardware to communicate with each other. If you are experiences a glitching display, unresponsive peripherals and sluggish performance, try the Dell Chromebook 5190 troubleshooting page for possible solutions before replacing the system board. If you are still experiencing these issues after troubleshooting, you may need a system board replacement.
Please make sure your laptop is off before beginning, and remove all cables or devices populating your laptop ports.
  1. Dell Chromebook 5190 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Motherboard Replacement: paso 2, imagen 1 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 2, imagen 2 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 2, imagen 3 de 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Motherboard Replacement: paso 3, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 3, imagen 2 de 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Motherboard Replacement: paso 4, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Motherboard Replacement: paso 5, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Motherboard Replacement: paso 6, imagen 1 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 6, imagen 2 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 6, imagen 3 de 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • To disconnect the first purple I/O cable, first lift the purple tab upwards.
    • Next, pull the purple tab away from the motherboard.
  8. Dell Chromebook 5190 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 8, imagen 2 de 2
    • To disconnect the second purple I/O cable, first lift the purple tab upwards.
  9. Dell Chromebook 5190 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 9, imagen 2 de 2
    • To disconnect the touchpad cable, first lift the purple tab upwards.
  10. Dell Chromebook 5190 Motherboard Replacement: paso 10, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 10, imagen 2 de 2
    • Push downwards on the black tabs located on both side of the motherboard connector.
    • Disconnect the keyboard cable.
  11. Dell Chromebook 5190 Motherboard Replacement: paso 11, imagen 1 de 1
    • Disconnect the speaker cable by pulling it from the motherboard connector.
  12. Dell Chromebook 5190 Motherboard Replacement: paso 12, imagen 1 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 12, imagen 2 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 12, imagen 3 de 3
    • Screw the single (M2x4) screw on the eDP bracket.
    • Unhook the eDP bracket.
    • Lift the eDP bracket off.
  13. Dell Chromebook 5190 Motherboard Replacement: paso 13, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 13, imagen 2 de 2
    • Remove clear adhesive tape off the motherboard connector.
    • Lift the black tab located on the display connector.
  14. Dell Chromebook 5190 Motherboard Replacement: paso 14, imagen 1 de 2 Dell Chromebook 5190 Motherboard Replacement: paso 14, imagen 2 de 2
    • Disconnect the display cable from the motherboard connector.
    • Remove the adhesive tape from the motherboard.
  15. Dell Chromebook 5190 Motherboard Replacement: paso 15, imagen 1 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 15, imagen 2 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 15, imagen 3 de 3
    • Unscrew the single (M2x4) screw from the motherboard bracket.
    • Unhook the motherboard bracket.
    • Lift the motherboard bracket.
  16. Dell Chromebook 5190 Motherboard Replacement: paso 16, imagen 1 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 16, imagen 2 de 3 Dell Chromebook 5190 Motherboard Replacement: paso 16, imagen 3 de 3
    • Unscrew 3 (M2x3) screws on the motherboard.
    • Unhook the motherboard by placing it at an angle.
    • Lift the motherboard.
Conclusión
Denise Cano
Miembro Desde 02/10/22
617 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-3, Pee Spring 2022 Miembro de Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 497
