Saltar al contenido principal
Dell Chromebook 3100 Battery Replacement
Jon
Jon y 4 otros contribuidores
Última actualización: December 2, 2024
25 segundo - 1 minuto
Fácil
Policía gramatical
Guía aportada por comunidad
Qué necesitas
Partes
Herramientas
  1. Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: paso 1, imagen 1 de 2 Dell Chromebook 3100 Battery Replacement, Remove Bottom Cover: paso 1, imagen 2 de 2
    • Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
    • Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
  2. Dell Chromebook 3100 Battery Replacement, #1 - Remove Battery Screws: paso 2, imagen 1 de 1
    • Remove the 3 battery screws with a Phillips #0 screwdriver.
    • Temporarily disconnect the sticker on the bottom left corner of the battery. You will need to reconnect this sticker when installing the new battery.
    • Lift the battery out of the palm rest. You may feel some resistance while trying to remove the battery. There is a piece of double-sided tape underneath the battery in the top left corner. (See video)
    • Disconnect the motherboard battery cable from the top of the battery.
Conclusión
Jon
Miembro Desde 08/18/13
3,921 Reputación
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 57
Todo El Tiempo: 1,314
