Saltar al contenido principal
Cosori Pro II Power Cord Replacement
Matthewmm
Matthewmm y 2 otros contribuidores
Última actualización: January 3, 2025
1 hora
Muy difícil
Necesita más imágenes
Mejor introducción
Qué necesitas
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Cosori Pro II Power Cord Replacement, Shell: paso 1, imagen 1 de 1
    • Flip the device upside down and remove all of the Phillips #1 screws.
  2. Cosori Pro II Power Cord Replacement: paso 2, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
    • Remove the panel.
  3. Cosori Pro II Power Cord Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove all four screws.
    • Lift off the bracket.
    • When lifting this off be careful to not unplug the screen.
  4. Cosori Pro II Power Cord Replacement: paso 4, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
    • Dissemble the shell going up to separate the basket holder.
  5. Cosori Pro II Power Cord Replacement: paso 5, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
    • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
  6. Cosori Pro II Power Cord Replacement: paso 6, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 6, imagen 2 de 2
    • Pull the bottom shell down pulling at the sides to get them over screw holes.
  7. Cosori Pro II Power Cord Replacement, Heating Coil: paso 7, imagen 1 de 1
    • Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
    • Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
  8. Cosori Pro II Power Cord Replacement: paso 8, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 8, imagen 2 de 2
    • Flip the device backward so the metal walls appear in a U-shape.
    • Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
    • Remove the heating coil.
  9. Cosori Pro II Power Cord Replacement, Motor/fan: paso 9, imagen 1 de 2 Cosori Pro II Power Cord Replacement, Motor/fan: paso 9, imagen 2 de 2
    • Remove the walls of the cooking chamber to get easier access to the fan.
  10. Cosori Pro II Power Cord Replacement: paso 10, imagen 1 de 3 Cosori Pro II Power Cord Replacement: paso 10, imagen 2 de 3 Cosori Pro II Power Cord Replacement: paso 10, imagen 3 de 3
    • Squeeze and disconnect the connectors.
    • Press the tab on the disconnector down then carefully pull it off to remove the wires from the board.
  11. Cosori Pro II Power Cord Replacement: paso 11, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 11, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two screws from the motor.
  12. Cosori Pro II Power Cord Replacement: paso 12, imagen 1 de 1
    • Remove the screws securing the heat detector using a Phillips #1 screwdrivers.
  13. Cosori Pro II Power Cord Replacement: paso 13, imagen 1 de 1
    • Using a 3/8" socket, unscrew the hex nut holding the fan in place, making sure to not apply to much pressure on the fan to avoid warping.
  14. Cosori Pro II Power Cord Replacement: paso 14, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 14, imagen 2 de 2
    • Remove each piece to the roof of the cooking chamber.
  15. Cosori Pro II Power Cord Replacement: paso 15, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 15, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the screws securing the motor.
    • Remove the motor.
  16. Cosori Pro II Power Cord Replacement, Cord: paso 16, imagen 1 de 3 Cosori Pro II Power Cord Replacement, Cord: paso 16, imagen 2 de 3 Cosori Pro II Power Cord Replacement, Cord: paso 16, imagen 3 de 3
    • Unhook the wires from the plastic hook.
    • Remove the two Phillips #2 screws that secure the blue and pink cables.
    • Use a Phillips #1 screwdriver to remove the single screw.
  17. Cosori Pro II Power Cord Replacement: paso 17, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two screws that secure the cylinder.
  18. Cosori Pro II Power Cord Replacement: paso 18, imagen 1 de 2 Cosori Pro II Power Cord Replacement: paso 18, imagen 2 de 2
    • Push the cylinder out.
    • Apply force to the hook on the connectors to take off the wires.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 49
Todo El Tiempo: 131
