Saltar al contenido principal
Canon Powershot ELPH 100 HS Outer Case Replacement
Jacob
Jacob y 8 otros contribuidores
Última actualización: May 20, 2022
10 - 25 minutos
Muy fácil
Introducción
Ir al paso 1
Hello everyone, this step by step guide will hep you put a new outer case replacement on your Canon Powershot ELPH 100 HS!
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: paso 1, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 2, imagen 1 de 1
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 3, imagen 1 de 2 Canon Powershot ELPH 100 HS Outer Case Replacement: paso 3, imagen 2 de 2
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 4, imagen 1 de 2 Canon Powershot ELPH 100 HS Outer Case Replacement: paso 4, imagen 2 de 2
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 5, imagen 1 de 2 Canon Powershot ELPH 100 HS Outer Case Replacement: paso 5, imagen 2 de 2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 6, imagen 1 de 1
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: paso 7, imagen 1 de 3 Canon Powershot ELPH 100 HS Outer Case Replacement: paso 7, imagen 2 de 3 Canon Powershot ELPH 100 HS Outer Case Replacement: paso 7, imagen 3 de 3
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
Conclusión
6 personas más completaron esta guía.
Jacob
Miembro Desde 03/17/15
570 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 20
Todo El Tiempo: 1,798
