Canon Powershot ELPH 100 HS Battery Replacement
Introducción
Ir al paso 1If your battery light has turned on for you camera, it is dying, and will need a new one, use this guide to help with replacing the battery. This is a very simple procedure, so you have nothing to worry about.
Locate the battery cover on the bottom of your camera.
Slide the tab to the right to open the battery cover.
Una persona más ha completado esta guía.
3 comentarios
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
