Saltar al contenido principal
Canon Powershot A3300 IS LCD Display Replacement
Kenny Chui
Kenny Chui y 5 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Difícil
Herramientas Incorrectas
Introducción
Ir al paso 1
This guide will show you how to replace a broken or malfunctioning LCD display.
Qué necesitas
  1. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: paso 1, imagen 1 de 3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: paso 1, imagen 2 de 3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS LCD Display Replacement: paso 2, imagen 1 de 2 Canon Powershot A3300 IS LCD Display Replacement: paso 2, imagen 2 de 2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS LCD Display Replacement, Front Cover: paso 3, imagen 1 de 2 Canon Powershot A3300 IS LCD Display Replacement, Front Cover: paso 3, imagen 2 de 2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS LCD Display Replacement, LCD Display: paso 4, imagen 1 de 1
    • Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
  5. Canon Powershot A3300 IS LCD Display Replacement: paso 5, imagen 1 de 1
    • Gently lift the LCD screen off the back of the camera.
  6. Canon Powershot A3300 IS LCD Display Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to pull out the circled brown flat flexible wire from its connection.
  7. Canon Powershot A3300 IS LCD Display Replacement: paso 7, imagen 1 de 2 Canon Powershot A3300 IS LCD Display Replacement: paso 7, imagen 2 de 2
    • Use a spudger to reach under the connecting wire.
    • Gently slide the spudger under the wire and lift the wire off the connection.
Conclusión
Una persona más ha completado esta guía.
Kenny Chui
Miembro Desde 10/17/17
122 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 26
Todo El Tiempo: 797
