Saltar al contenido principal
Canon PowerShot SX600 HS Power and Shutter Buttons Replacement
Jennyfer Munoz
Jennyfer Munoz y 2 otros contribuidores
Última actualización: September 15, 2017
1 - 5 minutos
Fácil
Introducción
Ir al paso 1
Canon PowerShot SX600 HS camera, can have a broken or damaged Power and Shutter Button. Problems with the Power and Shutter Button may prevent the camera from turning on or functioning properly. Use this guide when replacing the Power and Shutter Button.
Qué necesitas
Herramientas
  1. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Battery: paso 1, imagen 1 de 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 2, imagen 1 de 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 3, imagen 2 de 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Power and Shutter Buttons: paso 4, imagen 1 de 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 5, imagen 1 de 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 7, imagen 1 de 2 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 7, imagen 2 de 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: paso 8, imagen 1 de 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
Conclusión
Equipo
USF Tampa, Team S6-G4, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Miembros
9 Guías creadas
3 comentarios
Where does one buy an “opening tool”?
Evelyn Vose - Contestar
Where does one buy an “opening tool?”
Hello Evelyn,
you can buy it in the ifixit store. Otherwise you can use a plastic card you don’t need any more (it will be scratched and or bend afterwards, so you probably better don take a creditcard).
John Maier - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 828
