Saltar al contenido principal
Canon PowerShot SX520 HS LCD Screen Replacement
Lisa Choe
Lisa Choe y otro contribuidor
Última actualización: December 17, 2015
5 - 10 minutos
Moderado
Pasos faltantes
Introducción
Ir al paso 1
Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
Qué necesitas
Herramientas
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS LCD Screen Replacement: paso 2, imagen 1 de 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: paso 3, imagen 1 de 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: paso 3, imagen 2 de 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: paso 3, imagen 3 de 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS LCD Screen Replacement: paso 5, imagen 1 de 2 Canon PowerShot SX520 HS LCD Screen Replacement: paso 5, imagen 2 de 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS LCD Screen Replacement: paso 6, imagen 1 de 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: paso 7, imagen 1 de 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS LCD Screen Replacement: paso 8, imagen 1 de 1
    • Carefully pop out the LCD screen with your fingers.
Conclusión
Lisa Choe
Miembro Desde 09/22/15
460 Reputación
3 Guías creadas
Equipo
Baylor, Team 4-4, Williams Fall 2015 Miembro de Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 965
