Canon PowerShot SX520 HS LCD Screen Replacement
Introducción
Ir al paso 1Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
Qué necesitas
Herramientas
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
