Saltar al contenido principal
Canon PowerShot SX150 IS Screen Replacement
Madison King
Madison King y 6 otros contribuidores
Última actualización: May 7, 2024
7 - 20 minutos
Moderado
Introducción
Ir al paso 1
This guide will describe how to remove and replace the screen on your Canon PowerShot SX150 IS. This guide can be used to fix a cracked screen, or dead pixels in the screen.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Canon PowerShot SX150 IS Screen Replacement, Screen: paso 1, imagen 1 de 3 Canon PowerShot SX150 IS Screen Replacement, Screen: paso 1, imagen 2 de 3 Canon PowerShot SX150 IS Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove the 2 outer 5mm screws using the size J000 screwdriver.
    • Remove the one 5mm screw on the left and the two 4mm screws on the bottom.
    • Remove the two 2mm screws located above the screen on the back of the camera.
  2. Canon PowerShot SX150 IS Screen Replacement: paso 2, imagen 1 de 3 Canon PowerShot SX150 IS Screen Replacement: paso 2, imagen 2 de 3 Canon PowerShot SX150 IS Screen Replacement: paso 2, imagen 3 de 3
    • Remove the plastic panel surrounding the screen. (it should pop off easily)
    • Remove the one 5mm screws on the right using the size J000 screw driver from the button plate. Remove the two 4mm screws on the left, then move the button plate out of the way.
    • carefully unlatch and then detach the button plat's flex ribbon from the motherboard.
  3. Canon PowerShot SX150 IS Screen Replacement: paso 3, imagen 1 de 1
    • Lift the flex ribbon lock gently with your finger.
  4. Canon PowerShot SX150 IS Screen Replacement: paso 4, imagen 1 de 2 Canon PowerShot SX150 IS Screen Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use the tweezers to carefully detach the screen’s flex ribbon from the circuit board.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
  5. Canon PowerShot SX150 IS Screen Replacement: paso 5, imagen 1 de 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
  6. Canon PowerShot SX150 IS Screen Replacement: paso 6, imagen 1 de 1
    • Lift the screen out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 17
Todo El Tiempo: 731
