Canon PowerShot SD700 Motherboard Replacement
Introducción
Ir al paso 1Follow this step by step installation guide for replacing the motherboard on your Canon Powershot SD700 IS camera.
In order to make the process easier please view our more indepth guide on taking off the camera's casing in the LCD replacement guide.
Qué necesitas
Detach the LCD and backlight.
Remove the larger screw.
Remove the two smaller sized screws.
Remove the small screw.
With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
