Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PowerShot S230 Display Screen Replacement
Qué necesitas
    1. Canon PowerShot S230 Display Screen Replacement, Display Screen: paso 1, imagen 1 de 1
      • Unscrewing the small screws to take off the backing, screws are on the side and there are 4
      Pregunta a FixBot
      Agregar Comentario
    2. Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 1 de 3 Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 2 de 3 Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 3 de 3
      • Pry open the backing
      • Look for all screws before moving on
      Pregunta a FixBot
      Agregar Comentario
    3. Canon PowerShot S230 Display Screen Replacement: paso 3, imagen 1 de 1
      • Remove metal shield from camera
      • It's fine if you just use your hands
      Pregunta a FixBot
      Agregar Comentario
    4. Canon PowerShot S230 Display Screen Replacement: paso 4, imagen 1 de 1
      • Pry off the the front casing
      • REMOVE ALL SCREWS BEFORE MOVING ON
      Pregunta a FixBot
      Agregar Comentario
    5. Canon PowerShot S230 Display Screen Replacement: paso 5, imagen 1 de 2 Canon PowerShot S230 Display Screen Replacement: paso 5, imagen 2 de 2
      • Remove screws and metal shield at the bottom of the camera
      Pregunta a FixBot
      Agregar Comentario
    6. Canon PowerShot S230 Display Screen Replacement: paso 6, imagen 1 de 1
      • Remove the screen, also remove any screws that may get in the way, if the screen pops out it’s okay, it’s suppose to do that. Remove the screw at the bottom
      Pregunta a FixBot
      Agregar Comentario
    7. Canon PowerShot S230 Display Screen Replacement: paso 7, imagen 1 de 3 Canon PowerShot S230 Display Screen Replacement: paso 7, imagen 2 de 3 Canon PowerShot S230 Display Screen Replacement: paso 7, imagen 3 de 3
      • Remove the highlighted screws to remove the copper facing
      Pregunta a FixBot
      Agregar Comentario
      • Now that the screen is replaced, all you need to do is go through the steps in reverse!
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Angie
Miembro Desde 05/31/16
101 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 375
