Saltar al contenido principal
Canon PowerShot A540 Clock Battery Replacement
Cooper Hale
Cooper Hale y 4 otros contribuidores
Última actualización: September 24, 2024
5 minuto
Muy fácil
Introducción
Ir al paso 1
This guide will help you learn how to replace the internal CR1220 battery on your Canon PowerShot A540 camera. If your camera will not power on, or shows a battery error message and you've replace the AA batteries, the internal battery may need to be replaced.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Canon PowerShot A540 Clock Battery Replacement, Clock Battery: paso 1, imagen 1 de 1
    • Turn the camera upside down.
    • Press the tab to release the battery cover.
  2. Canon PowerShot A540 Clock Battery Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the internal Battery from the slot right above where the AA batteries fit.
    • This can be done with your fingers (as pictured) or with tweezers.
  3. Canon PowerShot A540 Clock Battery Replacement: paso 3, imagen 1 de 1
    • Replace the internal battery.
Conclusión
9 personas más completaron esta guía.
Cooper Hale
Miembro Desde 03/22/15
598 Reputación
3 Guías creadas
Equipo
Baylor, Team 7-12, Williams Spring 2015 Miembro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Miembros
20 Guías creadas
6 comentarios
Very useful information, thank you.
Bob C - Contestar
Also, nice fingernails!
Charlie Shaw - Contestar
I am a retired professional phographer with 60 years of experience and own several cameras including FX. Yet I didn’t remember how to change the clock battery on this little gem which I occasionally still use. Thanks for the refresher!
MASSEY JONES - Contestar
There is nothing in the manual concerning this battery. When I was told it needed replacement I was lucky to find this clear explanation to do it. It was a CR1220 battery. Thank you, Cooper Hale.
Thomas Combs - Contestar
Hello! I did this but my camera keeps saying that the battery is empty. Anyone know what else I can try? Or is my camera just broken?
Sanne x - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 40
Ultimos 30 días: 132
Todo El Tiempo: 10,151
