Canon PowerShot A3400 IS Flash Assembly Replacement
Introducción
Ir al paso 1The following steps will help you replace the flash assembly for the Canon PowerShot A3400 model. You would want to do this if the camera's flash is no longer functioning and you have exhausted your troubleshooting to the point where the source of the issue lies with the flash assembly.
Qué necesitas
Herramientas
Place thumb on area right next to where it says open and slide to the right to open.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
2 personas más completaron esta guía.
