Black and Decker PS1800 Motor Replacement
Introducción
Ir al paso 1This guide will show you how to replace the motor on the Black and Decker PS1800.
Qué necesitas
Herramientas
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Locate the motor at the top left hand corner.
Carefully disconnect the red and black wires attached to the motor.
Una persona más ha completado esta guía.
