Saltar al contenido principal
Asus ROG GL551J Screen Replacement
Thien Vu
Thien Vu y 6 otros contribuidores
Última actualización: May 16, 2022
30 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
Use this guide for instructions on how to remove the screen from your ASUS ROG GL551J laptop.
The screen is the output surface for a laptop, showing text and/or images to the user. If the laptop screen becomes cracked, it fails to display anything, or the images are distorted or discolored, it may need to be replaced.
Be sure that your laptop is completely powered off and disconnected from external power before beginning this guide. It is also recommended that you wear ESD (electrostatic discharge) gloves or rubber gloves to avoid damaging laptop components.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Asus ROG GL551J Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: paso 2, imagen 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: paso 3, imagen 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: paso 4, imagen 1 de 2 Asus ROG GL551J Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: paso 5, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 5, imagen 2 de 2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: paso 6, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: paso 7, imagen 1 de 1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: paso 8, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 8, imagen 2 de 2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Conclusión
Una persona más ha completado esta guía.
Thien Vu
Miembro Desde 02/15/17
412 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Lacy Spring 2017 Miembro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Miembros
5 Guías creadas
Un comentario
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 3,179
