Saltar al contenido principal
Asus ROG G752V Fan Replacement
Jeong
Jeong y 6 otros contribuidores
Última actualización: July 22, 2020
2 hora
Difícil
Introducción
Ir al paso 1
If your computer is overheating it may be due to a dirty or old fan. This guide will show you how to clean or replace the fan of Asus ROG G752V laptop.
Look at our Asus Rog G752V Troubleshooting page to identify the symptoms of a dirty or old fan. If your symptoms match, follow this guide to clean or replace your fan.
Before you start working, make sure that your Asus ROG G752V laptop charger is disconnected, and your laptop is turned off. In addition, follow the warnings that are attached to images in this guide.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Asus ROG G752V Fan Replacement, Battery: paso 1, imagen 1 de 2 Asus ROG G752V Fan Replacement, Battery: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Make sure you disconnect the charger before starting this guide.
    • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
  2. Asus ROG G752V Fan Replacement: paso 2, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Fan Replacement: paso 3, imagen 1 de 1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Fan Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Fan Replacement: paso 5, imagen 1 de 1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Fan Replacement: paso 6, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 6, imagen 2 de 2
    • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Fan Replacement: paso 7, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 7, imagen 2 de 2
    • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
    • Be gentle with the cover because there is a speaker wire attached to it.
  8. Asus ROG G752V Fan Replacement: paso 8, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 8, imagen 2 de 2
    • Disconnect the speaker wire.
  9. Asus ROG G752V Fan Replacement: paso 9, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 9, imagen 2 de 2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  10. Asus ROG G752V Fan Replacement: paso 10, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 10, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 10, imagen 3 de 3
    • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
  11. Asus ROG G752V Fan Replacement: paso 11, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 11, imagen 2 de 2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  12. Asus ROG G752V Fan Replacement: paso 12, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 12, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 12, imagen 3 de 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
    • Pull parallel to the motherboard, not straight up.
  13. Asus ROG G752V Fan Replacement: paso 13, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 13, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 13, imagen 3 de 3
    • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
    • This will unlatch the screen from the laptop entirely.
    • Remove the screen.
  14. Asus ROG G752V Fan Replacement: paso 14, imagen 1 de 1
    • Remove the four 5.8 mm screws securing the battery to the laptop.
  15. Asus ROG G752V Fan Replacement: paso 15, imagen 1 de 1
    • Use your hands to remove the battery.
    • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
  16. Asus ROG G752V Fan Replacement, Fan: paso 16, imagen 1 de 2 Asus ROG G752V Fan Replacement, Fan: paso 16, imagen 2 de 2
    • Unplug the fan-motherboard connection cable.
  17. Asus ROG G752V Fan Replacement: paso 17, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 17, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 17, imagen 3 de 3
    • Unscrew and remove the three 5.8mm screws on the small circuit board to the right of the right side fan with a Phillips #00 screwdriver.
    • Lift up the small circuit board covering the fan and put it aside.
  18. Asus ROG G752V Fan Replacement: paso 18, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 18, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the three 5.2 mm screws that connect the fan to the motherboard.
  19. Asus ROG G752V Fan Replacement: paso 19, imagen 1 de 1
    • With your hands, slowly and carefully lift up the right side fan.
  20. Asus ROG G752V Fan Replacement: paso 20, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 20, imagen 2 de 2
    • Carefully unlatch the left side fan cable from the motherboard.
  21. Asus ROG G752V Fan Replacement: paso 21, imagen 1 de 3 Asus ROG G752V Fan Replacement: paso 21, imagen 2 de 3 Asus ROG G752V Fan Replacement: paso 21, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the two 5.8mm screws that connect the left fan to the motherboard.
  22. Asus ROG G752V Fan Replacement: paso 22, imagen 1 de 2 Asus ROG G752V Fan Replacement: paso 22, imagen 2 de 2
    • With your hands, carefully lift the left fan and unlatch the fan from the motherboard.
Conclusión
4 personas más completaron esta guía.
1Guía Comentario
Awesome! Epic guide thank you!
Citizen Gone - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 62
Todo El Tiempo: 2,991
