Saltar al contenido principal
Asus M51E-B2  Swivel Camera Replacement
Juston Brown
Juston Brown y 3 otros contribuidores
Última actualización: January 9, 2019
20 minuto
Moderado
Introducción
Ir al paso 1
This guide shows you how to properly fix your laptop's swivel camera. This is an easy fix in order to get your camera to function properly. In order to accomplish this, you will need a dual-tipped metal spudger and a Phillips PH0 head screwdriver.
Qué necesitas
Herramientas
  1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: paso 1, imagen 1 de 1
    • Open the laptop.
    • Press and hold the power button until the laptop powers off.
  2. Asus M51E-B2  Swivel Camera Replacement: paso 2, imagen 1 de 2 Asus M51E-B2  Swivel Camera Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
    • Gently work your way clockwise around the outer part of the screen.
  3. Asus M51E-B2  Swivel Camera Replacement: paso 3, imagen 1 de 2 Asus M51E-B2  Swivel Camera Replacement: paso 3, imagen 2 de 2
    • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
    • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
  4. Asus M51E-B2  Swivel Camera Replacement: paso 4, imagen 1 de 1
    • Find the wiring harness on the right side of the camera.
    • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 357
