Saltar al contenido principal
Akai MPK25 Beat Pad Replacement
Serbinder Singh
Serbinder Singh y 6 otros contribuidores
Última actualización: January 28, 2014
Sin estimación
Moderado
Guía Destacada
Guía de Estudiante Destacada
Introducción
Ir al paso 1
Problems with the beat pad are common with this device. Use this guide to replace a defective beat pad sensor.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Akai MPK25 Beat Pad Replacement, Face Plate: paso 1, imagen 1 de 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Beat Pad Replacement: paso 2, imagen 1 de 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Beat Pad Replacement: paso 3, imagen 1 de 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Beat Pad Replacement: paso 4, imagen 1 de 3 Akai MPK25 Beat Pad Replacement: paso 4, imagen 2 de 3 Akai MPK25 Beat Pad Replacement: paso 4, imagen 3 de 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Beat Pad Replacement: paso 5, imagen 1 de 3 Akai MPK25 Beat Pad Replacement: paso 5, imagen 2 de 3 Akai MPK25 Beat Pad Replacement: paso 5, imagen 3 de 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Beat Pad Replacement, Beat Pad: paso 6, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the thirteen 9.8 mm silver screws holding the mother board to the face plate.
  7. Akai MPK25 Beat Pad Replacement: paso 7, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four 9.8mm screws holding in the base of the beat pad.
  8. Akai MPK25 Beat Pad Replacement: paso 8, imagen 1 de 2 Akai MPK25 Beat Pad Replacement: paso 8, imagen 2 de 2
    • Slightly lift the mother board near the edge of the beat pads and wiggle the beat pad ribbon connector free.
  9. Akai MPK25 Beat Pad Replacement: paso 9, imagen 1 de 2 Akai MPK25 Beat Pad Replacement: paso 9, imagen 2 de 2
    • Remove the beat pad sensor from the face plate.
Conclusión
Equipo
Cal Poly, Team 20-6, Maness Winter 2013 Miembro de Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
Miembros de 5
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 4,152
