Saltar al contenido principal
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
aaron thielk
aaron thielk y 5 otros contribuidores
Última actualización: February 19, 2016
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 1, imagen 1 de 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 1, imagen 2 de 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 2, imagen 1 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 2, imagen 2 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 2, imagen 3 de 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 3, imagen 1 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 3, imagen 2 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: paso 3, imagen 3 de 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Linea de Meta
Una persona más ha completado esta guía.
aaron thielk
Miembro Desde 10/10/10
1,903 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
Miembros de 4
17 Guías creadas
Un comentario
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 9,359
