Saltar al contenido principal
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
Hanna Flores
Hanna Flores y 7 otros contribuidores
Última actualización: June 26, 2024
5 - 10 minutos
Moderado
Introducción
Ir al paso 1
Welcome to the Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement Guide. In this comprehensive tutorial, we will walk you through the process of replacing the motherboard. The purpose of this guide is to assist you in replacing the motherboard . Whether you're experiencing hardware malfunctions or seeking an upgrade, this guide will provide you with step-by-step instructions to accomplish this task effectively. The motherboard is a crucial component of your laptop, serving as the main circuit board that houses the CPU, RAM, and other essential hardware components. It facilitates communication between these components and ensures the proper functioning of your device. Symptoms indicating a faulty motherboard may include:
  • Failure to power on
  • Random shutdowns or freezes
  • Unresponsive USB ports
  • Display issues
Tips and Warnings:
  • Exercise caution when handling electronic components, and use ESD-safe tools to prevent damage from static electricity.
  • Disconnect the power source and remove the battery before performing any repairs to avoid electrical hazards.
  • Ensure you have backed up important data from your hard drive before beginning the replacement process.
  • Properly dispose of the old motherboard and other electronic waste according to local regulations.
By following this guide diligently and adhering to the safety precautions outlined, you can successfully replace the motherboard of your Acer Aspire One Cloudbook AO1-132-C3T3 and restore its functionality. Let's get started!
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 2, imagen 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 2, imagen 2 de 2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 3, imagen 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 5, imagen 1 de 1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 6, imagen 1 de 2 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 6, imagen 2 de 2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 7, imagen 1 de 1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 8, imagen 1 de 1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: paso 9, imagen 1 de 1
    • Gently pull the motherboard away from the small square chip to its left.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 1,201
