Saltar al contenido principal
Acer Aspire E5-571 Battery Replacement
daniel sawyer
daniel sawyer y 5 otros contribuidores
Última actualización: June 19, 2024
1 minuto
Muy fácil
Mejor introducción
Introducción
Ir al paso 1
Can't seem to charge your battery? It may be time to replace it. This guide will walk you through the simple steps to access and replace the battery from your Acer Aspire E5-571 laptop.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  1. Acer Aspire E5-571 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: paso 2, imagen 1 de 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery towards you to remove it from the laptop.
Conclusión
8 personas más completaron esta guía.
daniel sawyer
Miembro Desde 08/23/15
2,602 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-2, Meier Fall 2015 Miembro de USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Miembros
5 Guías creadas
2 comentarios
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - Contestar
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 24,240
