Saltar al contenido principal
ASUS VivoBook S400C Battery Replacement
Ashley Panduro
Ashley Panduro y 4 otros contribuidores
Última actualización: May 18, 2022
5 minuto
Fácil
Guía aportada por comunidad
Guía de Estudiante Destacada
Introducción
Ir al paso 1
If your ASUS VivoBook S400C has an extremely short battery life or does not hold a charge, use this guide to replace the battery.
Over time, a battery may degrade in quality and fail to hold a long charge or take a charge at all. Before using this guide, check that no other factors are preventing a charge.
Before beginning, make sure your laptop is powered off and disconnected from any external power source. Take extra care if your battery is swollen .
Qué necesitas
Herramientas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. ASUS VivoBook S400C Battery Replacement, Remove the Bottom Cover: paso 1, imagen 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Battery Replacement: paso 2, imagen 1 de 2 ASUS VivoBook S400C Battery Replacement: paso 2, imagen 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Battery Replacement, Disconnect the Battery: paso 3, imagen 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Battery Replacement, Battery: paso 4, imagen 1 de 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Battery Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery up and out of the device.
Conclusión
Una persona más ha completado esta guía.
Ashley Panduro
Miembro Desde 10/16/19
572 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 2,215
