Saltar al contenido principal
8BitDo Ultimate Wired Bumper Replacement
Tanvi Verma
Tanvi Verma y 3 otros contribuidores
Última actualización: May 31, 2024
Sin estimación
Moderado
Introducción
Ir al paso 1
If you need to replace the bumpers on your controller you can access them with this guide. You may need to replace the bumper if it is cracked or not responding when pressed. For this guide, you will need a plastic opening tool and a TR6 Torx Security screwdriver.
You will not need to do any difficult steps, but be careful to not damage anything when you take off the top panel. Make sure the control is not plugged into a power source or operating system.
Qué necesitas
Herramientas
  1. 8BitDo Ultimate Wired Bumper Replacement, Bumper: paso 1, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement, Bumper: paso 1, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement, Bumper: paso 1, imagen 3 de 3
    • Orient the controller such that the back of the controller is facing you.
    • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
  2. 8BitDo Ultimate Wired Bumper Replacement: paso 2, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 2, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 2, imagen 3 de 3
    • Pry the other grip panel off using the same method.
  3. 8BitDo Ultimate Wired Bumper Replacement: paso 3, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 3, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 3, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm torx screw on the backside.
    • Use tweezers to help remove the screws (optional).
  4. 8BitDo Ultimate Wired Bumper Replacement: paso 4, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 4, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 4, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
  5. 8BitDo Ultimate Wired Bumper Replacement: paso 5, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 5, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 5, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
  6. 8BitDo Ultimate Wired Bumper Replacement: paso 6, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 6, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 6, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
  7. 8BitDo Ultimate Wired Bumper Replacement: paso 7, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 7, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 7, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
  8. 8BitDo Ultimate Wired Bumper Replacement: paso 8, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 8, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 8, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
  9. 8BitDo Ultimate Wired Bumper Replacement: paso 9, imagen 1 de 2 8BitDo Ultimate Wired Bumper Replacement: paso 9, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
  10. 8BitDo Ultimate Wired Bumper Replacement: paso 10, imagen 1 de 2 8BitDo Ultimate Wired Bumper Replacement: paso 10, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
    • A ribbon cable connects the front and back portions of the controller.
  11. 8BitDo Ultimate Wired Bumper Replacement: paso 11, imagen 1 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 11, imagen 2 de 3 8BitDo Ultimate Wired Bumper Replacement: paso 11, imagen 3 de 3
    • Orient the controller such that the back is facing you.
    • Use tweezers to help pull out the black piece on the top right side.
    • Simply pull out the loosened piece with the force of your hand.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 88
Ultimos 30 días: 293
Todo El Tiempo: 1,235
