8BitDo Ultimate Wired Bumper Replacement
Introducción
Ir al paso 1If you need to replace the bumpers on your controller you can access them with this guide. You may need to replace the bumper if it is cracked or not responding when pressed. For this guide, you will need a plastic opening tool and a TR6 Torx Security screwdriver.
You will not need to do any difficult steps, but be careful to not damage anything when you take off the top panel. Make sure the control is not plugged into a power source or operating system.
Qué necesitas
Orient the controller such that the back of the controller is facing you.
Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
2 personas más completaron esta guía.
