Saltar al contenido principal
Guías de reparación y soporte para almacenamiento portátil externo de Western Digital, incluida la serie My Book, My Passport y otros.
Preguntas 20 Ver todo
WD3200bevt won't show in finder, but shows in Disk Utility
I have a western digital my passport 320GB 2.5" SATA drive. After being put up for a couple of months, it isn't mounting to my macbook. I bought a new USB cable to test if that was the issue and it still isn't working.
I ran the first aid in disk utility, but that didn't help me much:
"Verifying partition map for “WD 3200BEV External Media”
Checking prerequisites
Checking the partition list
Checking for an EFI system partition
Checking the EFI system partition’s size
Checking the EFI system partition’s file system
Checking all HFS data partition loader spaces
Checking Core Storage Physical Volume partitions
Checking storage system
Checking volume.
disk2s2: Scan for Volume Headers
disk2s2: Scan for Disk Labels
Logical Volume Group F3FA9EC9-AD3F-41D0-BE14-A2ACD4C63786 spans 1 device
Logical Volume Group has a 16 MB Metadata Volume with double redundancy
Start scanning metadata for a valid checkpoint
Load and verify Segment Headers
Load and verify Checkpoint Payload
Load and verify Transaction Segment
Incorporate 1 newer non-checkpoint transactions
Load and verify Virtual Address Table
Load and verify Segment Usage Table
Load and verify Metadata Superblock
Load and verify Logical Volumes B-Trees
Logical Volume Group contains 1 Logical Volumes
Load and verify C6B2C4EC-0303-4889-B804-11E2C26ADDC8
Load and verify 209AAD8D-889E-4FA0-9268-2602DC9F18CB
Load and verify Freespace Summary
Load and verify Block Accounting
Load and verify Segment Cleaning
Newest transaction commit checkpoint is valid
The volume F3FA9EC9-AD3F-41D0-BE14-A2ACD4C63786 appears to be OK.
The partition map appears to be OK"
and then i ran another verify disk for the main partition:
"Verifying volume “DEREK”
Checking storage systemUnable to examine /dev/disk3: Resource busy
Error: Storage system verify or repair failed."
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
If it isn't this issue you have either a wonky external case, or HD. Often, as a lightbulb may "flicker", a failing HD may appear to work for a bit, then go bad. Should you get it to mount, backup all essential files. If you need to backup files, DiskWarrior, or Data Rescue 3 are two applications that I would recommend. If you have no essential files on it you can try a repartition... but generally once something like this happens you can't really trust that device for anything really important.
''If this answer was helpful please remember to return an mark it Accepted.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
derek3191 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,947
