Saltar al contenido principal
The Sony Smart Watch SW2 is a smartwatch created by Sony. The model number for the device is SW2 1271-4651.1.
Preguntas 3 Ver todo
The smart watch doesn't turn on
I was using it for long but now the watch doesn't turn on after charge. Plz advise
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
If your Watch isn't turning on after charging, here are some steps you can try to troubleshoot the issue:
Check the Charger and Cable: Ensure that the charger and cable are functioning correctly. Try using a different USB cable and charger if possible.
Charge Longer: Leave it plugged in for at least 30 minutes to an hour. Sometimes the battery might be too depleted to power on immediately.
Force Restart: If the watch is unresponsive, try a force restart: Hold the power button for about 10-15 seconds until the watch vibrates.
Software Issues: If it powers on but doesn’t function correctly, it might need a software reset or update. You can do this via the companion app on your smartphone.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nayak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 26
