Saltar al contenido principal
Lanzada en América del Norte en noviembre de 2006.
Preguntas 20 Ver todo
Why won't my new disc drive read?
After purchasing one of IFixIt's new disc drives and installing it, the disc spins upon startup and then stops, followed by the unable to read disc error. At first I thought it was because I didn't reset the Wii before inserting a disc, but I tried that too with the same result. I'm no expert (have only refurbished two yardsale Wii's in the past), but all of the solders and wiring seems secure, and I can't find any bent or broken pins inside of the connections. While waiting for the disc drive to arrive, I also replaced the thermal pads and gave the entire console a good clean. Could there be something that's not in the disc drive that causes a disc read error?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
Regarding your issue it could be multiple things. I had this issue once a long time ago, in this case it was the drive it's ribbon cable. (Drive > Motherboard).
I would replace this one first and see if that fix it.
Good luck with the repair!
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
TetriLys estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 34
