Saltar al contenido principal
El Maxima de sexta generación, con el nombre en código A34, solo se vendió en los Estados Unidos, Canadá y México. Fue presentado en forma de producción como modelo 2004 en el North American International Auto Show 2003.
Preguntas 20 Ver todo
Car won't start or crank
  • All fuses where pulled when I put them back in car won't start hear a click behind fuse panel in the blue looking relays I guess they are called, car started fine before interior fuses where pulled and put back in
  • Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Check the relays that are ignition / starting related and fuses nearby. Clicking makes me think a relay coil is pulling in but perhaps the contacts aren’t plugged down (relay is not all the way engaged (pressed) into its socket) or an associated fuse is not pressed down. Basically pull them out again and carefully reseat each one back into its socket.
Fue útil esta respuesta?
Puntuación 1
A simple “turn off and turn on again” system should work here. Try pulling out the interior fuses and putting them back into place, making sure they attach properly.
Puntuación 0
Añadir tu respuesta
James Birkes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 662
