Saltar al contenido principal
Pantalla de 4 pulgadas / Disponible en una variedad de colores / Lanzado en 3 modelos diferentes / Capacidad de 16, 32 o 64 GB
Preguntas 20 Ver todo
Battery won't work after two replacements
I ordered a battery to replace my ipod’s battery but it did not work so I ordered another one which came in today. I replaced it but it did not work as well. I don’t know what the problem is.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios:
did you connect the battery cables correctly?
- de
Yes I followed the tutorial. But I just checked everything again and turns out one of the metal pads on the motherboard where the battery is suppose to be soldered is gone. Does that affect it at all?
- de
Send a picture
- de
Agregar un comentario
1 Respuesta
It can be that its works but you screen is dead. Try connecting to iTunes and see if it discovers it if it does its probably a screen issue. If it doesn’t work on iTunes then I would think it’s the logic bored. Its also possible that the batteries you bought come at 0% charged and your dock connector is broken so you cant charge it. So what I would recommend you to do first it to replace the screen. If that doesn’t work then let me know and we will work from there. Also it would be a good idea if you can get around 30 day free return on whatever you buy for your iPod touch because there is a big chance that you will have to return it.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
www.jim.yang311 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 85
