sd card won't come out of camera
The sd card is stuck in the camera. Any ideas as to how to get it out. Have tried tweezers and it still won't come out keep pushing but no luck getting it to pop out as it normally does.
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
Hi, I think the spring mechanism might be jammed. What u need to do is push the sd card down gently and gently turn the card, and try to pull the card out. The key is patience and be gentle. Write back on what u did. Good luck.
Fue útil esta respuesta?
thanks it worked
I have the same issue & I got its solution later. So i can help you.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,028
