Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 6
Get your picks ready! To get any deeper into this camera, the right-hand port cover assembly must be removed first. Once this is removed, you will have access to the screws that secure the other components. There's a tiny hole toward the bottom right of the battery compartment. Using the pick tool, press into that hole.
  • Get your picks ready!
  • To get any deeper into this camera, the right-hand port cover assembly must be removed first. Once this is removed, you will have access to the screws that secure the other components.
  • There's a tiny hole toward the bottom right of the battery compartment. Using the pick tool, press into that hole.
  • A plastic rod will release. That plastic rod is the axis the hinge rotates about.
Insertar traducción aquí
