Saltar al contenido principal
Dell XPS 17 L702X Motherboard Replacement
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Dell XPS 17 L702X Motherboard Replacement: paso 0, imagen 1 de 2 Dell XPS 17 L702X Motherboard Replacement: paso 0, imagen 2 de 2
  • Gently flip the laptop with its bottom facing you.
  • Remove the four 8mm screws with a Phillips screwdriver.
  • Remove the two 16mm battery casing screws with a Phillips screwdriver.
  • Remove the two 16mm corner screws with a Phillips screwdriver.
  • Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
  • Removing the RAM is optional. This guide does not cover the removal of the RAM card.
Insertar traducción aquí
