Saltar al contenido principal
Dell Latitude E6500 Teardown
Inglés
Español
Paso 10
Dell Latitude E6500 Teardown: paso 0, imagen 1 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 2 de 3 Dell Latitude E6500 Teardown: paso 0, imagen 3 de 3
  • Removing Modem card if applicable.
  • Locate Modem bay on the middle left of the laptop next to the cooling assembly.
  • Disconnect the ribbon cable by unlocking the two side pressure pins, then pulling the ribbon cable free little force is necessary.
  • Remove 1 screw using a #0 Philip Screwerdriver.
  • Pull the modem card out but be careful because there is another cable underneath it.
  • Remove the 2 pin cable from underneath from the 2 pin header found on the modem card's PCB.
Insertar traducción aquí
