Saltar al contenido principal
HP Pavilion dv6000 Motherboard Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Paso 16
HP Pavilion dv6000 Motherboard Replacement: paso 0, imagen 1 de 3 HP Pavilion dv6000 Motherboard Replacement: paso 0, imagen 2 de 3 HP Pavilion dv6000 Motherboard Replacement: paso 0, imagen 3 de 3
  • Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically.
  • Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only.
  • Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
Insertar traducción aquí
