Saltar al contenido principal
Nikon Coolpix P90 Eyepiece Replacement
Inglés
Español
Paso 7
Nikon Coolpix P90 Eyepiece Replacement: paso 0, imagen 1 de 2 Nikon Coolpix P90 Eyepiece Replacement: paso 0, imagen 2 de 2
  • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector. This is the unlocked position.
  • Be careful when releasing the safety latch because it is fragile and may break easily.
  • Use tweezers or your fingers to gently pull the cable out of its socket.
  • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
  • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  • Remove the metal bracket from the camera.
Insertar traducción aquí
