Saltar al contenido principal
iPad Mini 3 Wi-Fi Logic Board Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 17
iPad Mini 3 Wi-Fi Logic Board Replacement: paso 0, imagen 1 de 2 iPad Mini 3 Wi-Fi Logic Board Replacement: paso 0, imagen 2 de 2
  • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Flip the iPad back over and insert a plastic card between the logic board side, speaker end of the battery and the rear case.
  • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
Insertar traducción aquí
